Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
2193 Soru Tümünü görüntüle
Will not restore to factory settings
I got a iPhone 4s from my friend and he told me to fix it but I have tried to put it in recovery mode and DFU mode but both do not work I need help guys I need to know what to do from here...?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Does it say anything when you plug in the Iphone to your computer? and its not the charger cord correct?
Just need more info! Thanks in advance!
Bu yanıt yardımcı oldu mu?
Puan 1
9 Yorum:
It says you have to unlock the iPhone before iTunes can sync the phone
tarafından
The charger works fine
tarafından
and you have trusted the computer? if not, try doing that. and if you did, maybe try disabling the passcode on the iphone under settings and then "Touch id and passcode". then type in your current passcode and disable the "Iphone unlock" option. Good luck!
tarafından
Oh sorry , It is disabled now and it says connect to iTunes and my computer is a Mac
tarafından
And it has never been synced to the computer before
tarafından
4 tane daha yorum göster
Yorum Ekle
Put the phone one and confirm if the Home button works. If it doesn't you have to change it.
If the button works then it may be the lightning port - 1st try to clean in inside if still doesn't work - change it.
Let me know how it goes.
Puan 0
1 Yorum:
The home button works and I have cleaned out the port and changed cords and still doesn't work
tarafından
Yorum Ekle
Yanıtını ekle
Ty Roessler sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 83
