Ana içeriğe geç
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
Charging problem after battery replacement
Replaced the battery on my iPad 3 today due to the old battery not charging. The problem I am having is after I replaced the battery the iPad now continuously connects and disconnects while plugged in. I have triple checked all of the connections and everything is plugged in properly and all connections are clean. Any idea as to why this is happening?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
When you say you have triple checked the connections, have you checked to make sure the contacts on the battery are making a good connection to the motherboard? Did you test the charging and functionality before closing the iPad back up?
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I initially thought that might have been the issue so I put a small shim under the battery contacts. That did not solve the issue. I closed the iPad back up, but it's easy to tear down again if I need to because the adhesive needs replaced.
tarafından
Yorum Ekle
Sounds like it might not have been the battery that was the culprit in the first place. Do you have a new charging port to try? Worst case scenario it might be an IC issue, more specifically the U2 IC might be fried.
Puan 1
1 Yorum:
I don't have a new charging port, but I can easily get one. I'll replace it and update.
tarafından
Yorum Ekle
Yanıtını ekle
jeninholland02 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 288
