The car is not moving it is making a sound when engaging gears
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@larrylk , Kelerile , You do not state auto or standard transmission which would help. If every thing seemed fine and you see no fluid leaks and transmission fluid levels good, you may have broken a CV joint(constant velocity joint) not allowing wheels to drive when one breaks. This is not the only thing that could cause this though, transmission,clutch,differential,etc could be bad. Have a good technician have a look and diagnose and estimate repair. Good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 58
1 Yorum
@larrylk what exact model is your HOnda? Engine size? Manual or automatic?
oldturkey03 tarafından
