Ana içeriğe geç
A digital camera designed and manufactured by Sony in 2012. A 18.2 megapixel camera with Wi-Fi, GPS, and a memory card slot.
15 Soru Tümünü görüntüle
How to do a factory reset?
I've gone thru all the options on the Sony eSupport pages, it's a no go.
The power lite goes on, but nothing else works. The lil red "access lamp" (#25 in the manual, next to the sd card) flashes 2x then off, which may be an error code? The power lite goes off only if I remove the battery.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@paulieh01 this should work to reset your camera:
"The lil red "access lamp" (#25 in the manual, next to the sd card) flashes 2x then off" is an indicator for the memory card. You may have some problems with the card. Remove and/or replace it it and see if that changes anything.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Paulie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 2,041
