Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
773 Soru Tümünü görüntüle
Pop sound during boot and sometimes in macOS
Hi,
When I'm booting my mbp I can hear a loud pop sound, se video.
This happens 3 of 5 times during boot.
It does not matter if the mbp is warm or could, and it also happens during restarts.
Sometimes, but not often it happens in macOS also.
Today it did, the mbp did not have any load on it. It was just opend and I was talking in the phone when the pop sounded.
I have tried to stress test CPU,GPU,RAM and SSD but no sound.
I have manually tried different rpm on the fans nothing it sounds good.
I have tried smc/nvram reset.
I have tried reinstalling macOS.
The machine is only 2 days old.
So I'm curious what wrong with it? Because it's not normal.
Maybe something to do with the battery?
Can batteries pop?
Video of the pop:
https://youtu.be/zP18SUmSoQ8
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The only things it could be are the fans (which you have ruled out), trackpad (the force touch might be working on it's own, but I doubt it) or the speakers (most likely, especially since it does it at boot when it should chime).
You can try removing the bottom lid, and listening to where the clicking sounds are coming from (speakers are to the left and right of battery). If it is coming from the speakers, use a T5 screwdriver to remove them, it is possible there is dust under, or they are bad.
The best thing to do though is return it to where you got it from. If it is 2 days old, there will be a warranty :)
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
I have left it to repair and he could not isolate the issue but the mbp are running some tests.
As this was my fifth DOA I did email Tim Cook and one from apple called me up today.
They will talk with the repair guy and return to me tomorrow.
tarafından
Here is a other video when the click appears after I wake the mbp from sleep and during login.
https://youtu.be/_zDdm8ck2i8
tarafından
So what happened, what was the issue?
tarafından
Yorum Ekle
Puan 0
Yorum Ekle
Yanıtını ekle
Calby sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 698
