Phone Charge Port not Working
Hello,
I decided to ask this forum about this issue. My mom's phone is not charging anymore and we try see if it was dust or small particles but, it was not that. I am wanting to fix the port but, don't know where to start and My mom does not want buy a new phone.
Please help.
Bu iyi bir soru mu?
3 Yorum
I had just got a new charging port by Bentley tech support and It doesn't work, it's new though, so why don't it work?
Heyimagirllol tarafından
A faulty charging port is one of the most common smartphone issues. If your phone is charging slowly, charging only at a certain angle, or not charging at all, the problem may be caused by dust, lint, a damaged charging cable, or a worn-out charging port.
DIY Steps to Try
Inspect the charging port for dust or debris.
Gently clean the port using a soft brush or a wooden toothpick. Avoid using metal objects.
Try a different original charger and USB cable.
Restart your phone and check if charging resumes.
Test the charger with another compatible device to rule out charger issues.
If the problem continues after these steps, the charging port may require professional repair or replacement. Visiting an motorola authorized service center ensures proper diagnosis, genuine spare parts, and reliable repairs, helping restore safe and efficient charging performance.
Motorola Authorisednagpur tarafından
My charger is not working it loses battery instead of gaining power even with other chargers and I tried switching the box too what do I
Dakota Swint tarafından
