Ana içeriğe geç
The fourth-generation Surface Pro tablet, released October 26th, 2015.
208 Soru Tümünü görüntüle
Blurry texts and screen flickers
Texts are blurry, screen flickers and video/image moves under frozen one.
How to correct it ?
Image and text on the screen use to tremble, up and down, from time to time. When this happens image and text become blurry.
When video is playing,sometimes, one frame freezes, while in the background the video is still playing.
Is it a software related problem or a hardware malfunction ?
(once I hooked the Surface to a monitor, the video played fine,while the problem persisted on the Surface screen)
Bu iyi bir soru mu?
Puan 4
11 Yorum
Hi,
If it was software it should also affect the external monitor.
It could be a video cable or a tablet screen problem.
How long have you had the tablet?
tarafından
I have the same problem with my Surface pro 4, which I have had only for about 18 months, the problem started several months ago, and is getting worse. It makes it very hard to do projects! I have searched the Internet to see if there is a way to fix this problem. I love the Surface Pro 4, but unless Microsoft comes up with a solution, I would not buy another of their products like this! Microsoft needs to fix this, as many are experiencing the same issue!1
tarafından
My surface screen is going blurry, looking like multiple docs are open on top of each other. Can’t read any of it. Screen becomes unresponsive. Does anyone have any advice? Thanks
tarafından
I am experiencing the same thing on my surface pro!
tarafından
I just started having this problem. My surface pro 4 is about 17 months old. Happens when the device gets hot.
tarafından
6 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Call Microsoft, this is a known issue covered by extended warranty.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
This worked for me. https://www.groovypost.com/howto/fix-fuz...
Puan 0
Yorum Ekle
Yanıtını ekle
Emilcar Similien sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 16,884
