Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
When putting LCD down to fit display no longer shows.
Hi all,
I am currently doing an iPhone 6 LCD Replacement that is causing me trouble. When I am trying to sit the screen down it is coming up with no display a few cm's from being fitted or when it does display it has a dark backlight issue on the right hand side.
When I take out the earpiece it works fine with no backlight issue and the display doesnt turn off when lower down.
I have currently tried the following:
Changed the proximity sensor, earpiece, earpiece shield, home button flex LCD shield and have tried another LCD and the same problems occur.
I have tried covering the earpiece shield with tape and the proximity flex with tape just incase there is interference but no luck. I have also restored the phone.
All suggestions would be very helpful, thank you.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
My guess is the LCD FPC connector on the logic board may have some damage on it.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I thought this might be the case but was hoping not, it is a bit stiff when getting the flex into the connector, could you recommend anything other than replacement?
tarafından
Should be able to tell by visually inspecting via microscope.
I don't have any other suggestions as backlight missing on one or more sides of the screen is caused by a bad LCD connection.
tarafından
Yorum Ekle
All working now, fitted a new proximity sensor and also cleaned all connections with alcohol under a microscope, working perfectly now.
Puan 0
Yorum Ekle
Yanıtını ekle
PhoneAsylum sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 41
