Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
iPhone won't charge past 1%
I have an iPhone 5S ( iOS 9) which was water damaged, I had the inside of the phone cleaned out with alcohol. The phone now turns on but it will not change past 1%.
The phone will say that it is chargeing but won't gain any percentage.
If I install a new battery it will show that it is changing but will not go up. ( Actually going down a percentage after 30 mins).
Tried new charger port with no luck.
If I have any updates I will keep you posted.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The first thing to try is a new battery. I would recommend you buy it from iFixit if you can or a reputable vendor as there are many poor quality batteries on the market. Also, if you have access to a known-good battery, that would be even better.
Is your phone recognized by iTunes? If not, you may have a defective charge port or a failure of the charging circuit on the logic board. Considering that you had water damage, It could be anyone of those possibilities. If you did not remove the shields from the logic board, then you only cleaned ~20% of the board.
Let us know more about the extent of the water damage and what steps you took to clean it up.
iPhone 5s Battery Görseli
Ürün
iPhone 5s Battery
$29.99
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
Thanks for the info. Even with oem battery’s it’s doing the same thing. It’s a motherboard failure
tarafından
Yorum Ekle
Yanıtını ekle
iPhone 3GS KING sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 66
Her zaman: 22,561
