Ana içeriğe geç
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
stuck on start up
it starts and gets stuck on start up screen
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
Hi,
What OS is installed?
Have you tried starting in 'safe mode' to see if it boots all the way to the Windows desktop?
Have you tried booting using the 'last known good configuration option'?
Have you tried a system restore to a previous restore point?
tarafından
hello it doesnt load past the dell logo and the slide bar stops about a quarter of the bar and its running vista home premium
tarafından
Hi,
Can you get into BIOS?
Press F2 soon after startup.
If you can check that there is a HDD being detected in BIOS.
try pressing F12 soon after startup and see if you get into Dell's Diagnostic partition to test a custom test on the HDD to see if it is failing.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
With the power off, try removing all the memory sticks and see if you get a beep error or blinking LEDs (Power, Hard Drive and Wireless). If nothing happens then the processor is bad, if you get a beep or blink code it is probably the memory, you can go to the Dell site to get the information on the beep/blink codes.
The current Dell computers now use the LEDs for start up errors.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
dave_ruse sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 197
