Ana içeriğe geç
The Dyson AM07 is a bladeless tower fan released in 2014. The AM07 uses "Air Multiplier" technology to create a smooth stream of air without using visible blades.
Why is it not blowing cold air
My fan works but doesn't seem to be blowing out much cold air anymore
Bu iyi bir soru mu?
Puan 3
6 Yorum
I have the same problem. Paid £320 for the fan and it’s useless
tarafından
Keep it clean and should be fine, they do require some maintenance if it is in a dusty and fluff environment, get a vacuum cleaner and suck all the dust of the air intake and motor and amp as much as possible or it's that bad use a compressor as suggested before
tarafından
If these are used for heating and cooling, they get moist and the dust collected becomes wet and mud like and glues to the body closing all the vent holes. These can't be cleaned by a vacuum cleaner. It requires disassembling/opening the body of the air multiplier and if possible wash clean the intake holes.
tarafından
Opening the body is not simple, several step needed and some technical know-how.
tarafından
I just recently bought a Dyson cool fan but it’s not giving me cool air and there’s a smell when I turn it on
tarafından
1 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
loopyshaz222 , Try and disassemble the fan as much as you can and use vacuum/compressed air to blow out all the dust/lint/etc. that may have accumulated from base vents/motor and the loop to help bring back it's efficiency. Links below may help. Good luck.
https://www.manualslib.com/manual/888752...
https://www.youtube.com/watch?v=Y7Z-Zn0r...
https://www.youtube.com/watch?v=5NAQv6RX...
Bu yanıt yardımcı oldu mu?
Puan 5
Yorum Ekle
All this I have done.
I vacuum every other day.
Fine dust has clung to the inside fan. Thus impeding air flow.
Puan 1
Yorum Ekle
Yanıtını ekle
loopyshaz222 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 47
Her zaman: 67,786
