Ana içeriğe geç
Bu, paslanmaz çelikten üretilmiş, 4 dilim kapasiteli bir mini fırındır. Model numarası cihazın alt kısmında yer alır. Tek bir raf yüksekliğine ve çıkarılabilir bir kırıntı tepsisine sahiptir.
Toast dial timer is stalling
The bottom dial ( the toaster timer) keeps stalling and won't turn off. It ticks for a while but stops after a while. The at times works if the toaster is upside down or it's back.
Do you need to change the switch? Or is there another way to fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
Happened to me too. It's a potential fire hazard when the mechanical timer doesnt shut off the oven.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Alfred,
I suspect you'll probably end up having to replace the timer, but you could try cleaning it. I would imagine there's a fair chance it may be gummed up with oils, carbon and all kinds of other volatiles from cooking.
Get yourself a can of electrical parts cleaner and spray the heck out of the timer. The cleaner will evaporate completely so there won't be an residue left in it when you hook it back up and try it. If there are any openings in the timer, use the red tube to direct the spray inside to wash it out.
Outside of disassembling the switch, which may or may not be possible, that would be my best suggestion.
Hope it helps; let us know how it goes!
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thoughtful info, and so fast. Thanks!
tarafından
Yorum Ekle
Yanıtını ekle
Alfred Assin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 43
Her zaman: 1,320
