Ana içeriğe geç
Dymo LabelManager 160 hızlı, kompakt ve hafiftir; bu sayede hemen hemen her şeyi her yerde etiketlemeyi kolaylaştırır. Bilgisayar tarzı QWERTY klavyede hızlıca yazın, tek dokunuşlu hızlı biçimlendirme tuşlarıyla düzenleyin ve her seferinde kusursuz, profesyonel etiketler basın.
No charge no ink
My dymo keeps flashing low battery sign but I just changed the batteries also I have it plugged into the wall charger I believe this is also causing it to not print probably everything works like it should except there is no writing on the labels once they print out.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
MAGGIE , You could try another compatible charger as it may be faulty. Clean the battery contacts in machine using a pen with an eraser on he end as it is a little abrasive or a Qtip dampened with 90% Isopropyl Alcohol or better, clean the terminals well and then blow out the dust/debri and change the batteries out for some new good quality batteries and try. Good luck.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
In case someone else googles this like I did. I figured it out shortly after. My colleague had inserted a couple of the new batteries the wrong way. Check the direction of the batteries and it should fix this problem.
Puan 0
Yorum Ekle
I had the same problem. I rechecked how I installed the batteries and sure enough 2 of them were put in the wrong way. Corrected this and labels are printing correctly now.
Puan 0
Yorum Ekle
On mine I have checked the batterys a few times but it still won’t print, the machine is brand new but there is no ink, the baterys are new and good
Puan 0
Yorum Ekle
Yanıtını ekle
MAGGIE sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 7,342
