Ana içeriğe geç
Microsoft's third-generation Xbox game console, released November 22, 2013.
Power brick orange until I plug in the console
When I plug the power brick without the console an orange light is on, in the moment I plug it in the console it shuts down. I tried using the power brick with another console and it worked fine, and the other power brick did the same on my console. Any clue of what could be the problem?. I was wondering if the console has any fuse in it or some internal voltage regulator or similar, or maybe the processor or the motherboard are broken.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The power adapter has a built-in shut off switch that disables all power when a surge, overload, or short is detected. Since you have already tried a separate power adapter (one that was confirmed working), and it does the same thing you most likely have a problem with the internal hardware of the console.
Have you tried unplugging the console for more than 30 minutes so it completely loses any voltage and (more or less) resets? This may solve your no power problem.
You can also check this out. It has helped me before in the past.
https://gamersrepair.com/index.php/troub...
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Can you tell me where this overload or short is detected on the PSU as I would like to troubleshoot.
tarafından
Yorum Ekle
Looking at the if in the webpage you passed me it appears that the problem is in the motherboard. Thanks a lot for the hep!!
Puan 0
2 Yorum:
Can you relink that page?
tarafından
Hi,
I have recently had this problem and the link doesn't exist anymore. Is there a specific thing that is faulty on the motherboard? I'm wondering if it's something that i can fix myself? I would really appreciate if you reply :)
tarafından
Yorum Ekle
Yanıtını ekle
Javier Baizan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 40,739
