Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
How important is the ambient light sensor filter?
Heeey everyone :)
After looking around the net I haven't found an answer to my question, so here goes..
How important is the ambient light sensor filter (white square filter) and what are its functions?
Some people told me it's a optical filter and not necessary, while someone else told me it's a light diffuser.
On white screens it's a dot instead of a square.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The front camera flex should have a rubber gasket that sits on the pink ambient light sensor and has a small hole on it.
The sticker I think it's to make a good seal on the screen and the glass so that the sensor does not have like infrared or something bouncing somewhere else behind the screen.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
white screens should still be the same, its a white square on a white screen so im sure its just blending in, i dont see why it shouldn't and An ambient light sensor is a sensor that detects light to adjust the brightness of the screen. So not sure if its important, but you could remove it and see if it still works.
Hope this helps!
Puan 2
6 Yorum:
What does that sticker do? What function does it have?
tarafından
tarafından
Yes I know that lol, but what does the sticker do?
The sensor itself is on the flex cable, together with the proximity sensor and front camera.
tarafından
The sticker? I think its just used to protect the sensor from being damaged and possibly used to diffuse light. Those seem like the most logical reasons its there.
tarafından
It’s not a sticker it’s a filter, and you need it for auto brightness to work.
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Didier Daniel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 21
Her zaman: 6,132
