Ana içeriğe geç
16 Ekim 2014 tarihinde duyurulmuştur, A1347 model numarası ve 2840 EMC numarası ile tanımlanabilir.
Adding SSD Drive to PCIe model
Can anyone assist with what parts I would need to add an SSD to a Mac Mini 2014 that came with a PCIe 512 GB drive?
I'd like to make it a dual drive setup, but can't confirm what part is needed to do so. Any help would be greatly appreciated.
Bu iyi bir soru mu?
Puan 3
2 Yorum
me to i would like to recieve and so place a PCIE drive on my mac mini late 2014. can you send me the link for buying that item?
bst regards
tarafından
@yannick17 - Review my answer for the details
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you already have the PCIe SSD then you're adding a SATA drive (either a HD or a SSD) You'll need the to follow this IFIXIT guide Mac mini Late 2014 Sabit Disk Kablosu Değişimi and need this part & tool kit: Mac mini Dual Drive Kit. Be careful here! The size of the drive needs to physically fit (12 mm is about it).
If you have a SATA HD already then you'll want this: either the drive carrier with the SSD cable mounted Hard Drive Carrier w/ SSD Flex Cable - Apple P/N 076-00040 or the cable its self Cable, SSD Flex - Apple P/N 076-00018
Here's the IFIXIT guides:
All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini. Görseli
Ürün
$29.99
Mac mini Late 2014 PCIe SSD Kablosu Görseli
Kılavuz
Mac mini Late 2014 PCIe SSD Kablosu Değişimi
Zorluk:
Orta
15 - 20 minutes
Mac mini Late 2014 Sabit Disk Kablosu Görseli
Kılavuz
Zorluk:
Orta
1 hour
Mac mini Late 2014 Sabit disk tepsisi Görseli
Kılavuz
Mac mini Late 2014 Sabit Disk Tepsisi Değişimi
Zorluk:
Orta
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Dan, If I already have a fusion drive in there will I need any of these replacement parts, or can I just substitute the respective PCIe and 2.5 inch drives for the existing ones?
tarafından
You'll need to make a full backup before doing anything.
First step is to break the Fusion Drive following this How to split up a Fusion Drive.
And yes, all of the needed hardware sans the replacement drive/s is present.
But before you jump what is your goals here?
tarafından
Yorum Ekle
When adding a HDD to a PCIe SSD only 2014 mini, which HDD cable do you need? (1) the mini dual drive cable, or (2) the upper SATA cable?
Puan 0
Yorum Ekle
Yanıtını ekle
tomtcs sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 35
Her zaman: 2,011
