Tablet shuts down while playing games
Tablet shuts down while playing games. Tablet also will not open games app. - just closes automatically. Comes up with a box that says Thermal Shutdown. Thermal critical error occurred.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Your tablet is overheating.
If your tablet is in case, try taking it out. I have the same tablet and it tends to get hot and shut down.
Also, try some type of cooling pad or something that will allow air to get to the underside . That should help remove any build up of heat around it.
If it is heating up right after starting up, then you may have some internal problems. You might want to look into having someone look at it or finding a new tablet.
Good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 798
3 Yorum
How do I fix this problem
rdollen1 tarafından
Check the chosen answer for what you’re looking for.
Eric Viitala tarafından
how do i fix this on amazon kindle fire gen. 5
Albert Einstein tarafından
