Ana içeriğe geç
Why does my drone get a Jello-effect?
Why does my drone get a Jello-effect ?
I have tried to utdate everything, but nothing seems to make it better.
Blury picture on the phone while filming..
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
That must be from vibration. Most drones that don't have a damper have this problem, but that shouldn't happen with this one. If your under warranty, send it in to DJI so they can have a look at it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
@pccheese ,Cepeders, Blurry picture on the phone while filming, try a different device as maybe your phone is not linking properly. If under warranty consider using it for replacement/refund/repair. Check to see if the camera/lens is loose on the drone and vibrating around. You may have already done so, do a search( dji mavic pro drone blurry picture) as there is numerous post/articles/forums that discuss this issue. Find below a disassembly guide to get you inside the check for loose wires/components/etc. that could cause an issue. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
DJI Mavic Pro Sökümü
Puan 2
Yorum Ekle
Yanıtını ekle
Cepeders sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 2,041
