Ana içeriğe geç
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
317 Soru Tümünü görüntüle
Tweaking with Anglebird SSD in MacPro 2009-12
Does anyone have any actual experience with using an Anglebird SSD drive?
https://www.angelbird.com/prod/ssd-wrk-6...
It does have TRIM support which the other mainstream drives do not appear to have.
I am currently using an 512GB X400 Sandisk SSD as my boot drive on a 2x 2.93 GHz Quad-Core Xeon. Flashed to 5,1 running 10.12.3. Recently added a 4 port USB3 PCI card.
http://www.pro-tools-expert.com/home-pag...
@danj, @reecee
Next I'm looking at just how much of a CPU upgrade to go to (and what I can afford, a bit pricey at $1,785) 12-Core 3.46GHz Apple Mac Pro CPU Tray Upgrade Westmere 2009 2010 4,1 5,1 128GB http://www.ebay.com/itm/12-Core-3-46GHz-...
Does anyone have experience with the processor upgrades beyond what Apple has put out? http://create.pro/blog/3-46ghz-12-core-m...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@mayer as of OS X 10.10.4, the new command 'trimforce' was introduced that enabled TRIM on any SSD installed in Macs.
Simply open a terminal and type 'sudo trimforce enable' and enter your password.
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
Thanks @avanteguarde, IU'll give that a try. Thanks for teaching the old dog a new trick ;-) http://osxdaily.com/2015/10/29/use-trimf...
PS, It's time to expand your profile so we can get to know you better. looks like you may be a keeper ;-)
tarafından
I also use the trimforce with the newest OS-X & MacOS this works for any SSD.
Anglebird SSD for a time was the only way to get native Apple TRIM services. Not sure I fully understand how they got away with it. As far as I know they are just emulating the Apple SSD ID string the firmware looking for during POST.
tarafından
@mayer for the cpu's dud you check youtube? theres many tourtials on how to do things like that and im pretty sure you can replace only the cpu for a few hundred instead of 1700
tarafından
Yorum Ekle
Yanıtını ekle
mayer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 206
