Ana içeriğe geç
2006 yılında piyasaya sürülen, e1505 modeli için PP20L model numarasıyla tanımlanan dizüstü bilgisayar
Overheating issues-RAM or GPU
My Dell laptop has been overheating when watching Netflix. After about 5 minutes of watching, the fan begins to ramp up, and after 10, it goes to full. I suspect either the RAM or the Intel 945GM graphics chipset. I have upgraded the CPU to core 2 duo T7600, and the RAM to 2x2 A-TECH PC-6400 RAM. HWmonitor does not display any abnormal tempatures, but when I touch the RAM it feels quite hot (around 50° c), but still not out of normal threshold. When I replaced the CPU, I noticed that the graphics chipset had a peice of thermal tape instead of thermal paste. I replaced it with thermal paste, not thinking it made a difference. Operating system-windows 10, and yes, I am using it on a hard surface. Thanks for any help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum
@pccheese, have you made sure the fan(s) are spinning and the vents aren't blocked? Have you tested your RAM yet with a memory checker program?
tarafından Paylaş
@avanteguarde Yes, my fan has plenty of free space. I have not yet checked my RAM.
tarafından Paylaş
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I am surprised that you were able to upgrade the processor. The problem may be that the cooling system was not designed for the upgraded processor and is not able to cool it properly. The heat sink compound on the GPU may not be contacting the heat sink surface, the silicone heat strip is thicker and would contact both the GPU and the heat sink. At a minimum, put the silicone strip back in place.
I would recommend going into diagnostics to test the CPU, heat sink and fan. Press F12 at the Dell splash screen and pick the menu option for diagnostics. The test you want is the CPU stress test, if the temperature get above 80 degrees Celsius ( water boils at 100 Celsius), then the heat sink is not sufficient for the upgraded CPU. You can try to get another heat sink asby and fan to see if it improves cooling performance.
Bu yanıt yardımcı oldu mu?
Puan 2
5 Yorum:
A. Windows is pure windows 10, and it doesn't have the Dell start up screen, just the bios which is version A17.
B. The CPU is only 3 watts more, not enough to make a difference. It runs at about 43°c while watching. Again, GPU or RAM.
C. I'm sure that the thermal compound is full between the graphics chipset and heatsink. I will install MSI kombuster to check GPU temp.
tarafından Paylaş
A. The Dell splash screen is part of BIOS not windows. B. Suspect GPU not RAM
tarafından Paylaş
I ran the diagnostics. No problems. I have yet to do other stuff.
tarafından Paylaş
What do you consider hot for ram?
tarafından Paylaş
RAM has more tolerance to heat and is generally air cooled. Since memory is involved in everything, if it goes bad it will show up as weird characters, incomplete refresh of desktop. Hot would be too hot to touch.
tarafından Paylaş
Yorum Ekle
Hi, you may look into these odds may happens due to:
Check your Bios for any odd OC
Look if your machine having direct temprature
Check the connection between heatsink & processor
Is youre fan spinning & blowing infront of heatsink
Clean or replace thermal paste between processor & heatsink
Puan 1
3 Yorum:
Yes, I'm sure all these things are up to snuff. It's an 11 year old laptop, so overclocking isn't even possible. What do you mean "having direct tempature."
tarafından Paylaş
its been great to use 11 years old laptop, laptop must be a friend now, well "having direct temperature" means direct sunlight or using in the open filed.
tarafından Paylaş
No, my laptop is in an air conditioned​ house.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
George A. sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 1,377
