turn off safe mode
how to disable safe mode I'm already try all think but no work please replyme fast because I need some app
Bu iyi bir soru mu?
Bu iyi bir soru mu?
There are several ways to disable safe mode . Some phones you need to just shut off and reboot . Others need be rebooted from the android menu. Select boot normally . You can also try removing the battery. Then reinstall it and reboot. or you can also go to the android menu and select wipe cache partition. One of these should reset your phone to a normal boot. Hope this helps
Bu yanıt yardımcı oldu mu?
Safe mode off samsung j2
Hi @ Rohit Chudasma,
As @jimfixer said to turn off safe mode on Samsung Galaxy J2:
Press and hold the Power key.
Tap Restart.
Safe mode disable krne ka kya
if the safe mode was locked with PIN code and didn't know the code
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 20,597
