Bluetooth not connecting spinning wheel
Bluetooth won't connect and clock stops on screen lock
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Some hit on your phone recently ? Sounds like a fault of the wifi & BT IC, or on the joints soldering it to the logic board. Quite a common issue on 5Cs as Russ pointed out, but it's most probably a hardware failure.
With a little luck and skills it might get fixed by a reflow of the chip.
Bu yanıt yardımcı oldu mu?
How do I do a hip reflow ? Gordon
Easier said than done, as usual. Best advice I can give is to find a phone repair shop where the basic tools should be ready available and they can give a try the proper way. Some reported having had some success with home tools such as a oven or a heat gun, but the risk of trashing the entire board is pretty high. Since you don't have much to loose, you might want to give it a try anyway. If you are brave enough you can google a bit to find the way that suits best the tools you got at home.
To remove the board you can use this guide: iPhone 5c Logic Board Replacement
Thanks all you guys for your help, by doing what you have said I have come to the conclusion that the wifi board is faulty, my phone will connect to wifi but cannot connect to outside e.g google, thank you again Gordon
You're welcome, but maybe next time chose as aswer the right one ;)
Upgrade to IOS 10.3.1 solved the problem on my IPhone5 and my daughter's Iphone6.
Good luck,
Russ
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 10,629
2 Yorum
If you upgraded tp IOS 10.2.1, that is probably the source of your Bluetooth problem. That is a widespread problem which Apple has not yet addressed. Good luck.
Russ
Russ Walden tarafından
Just upped to 10.3 just the same but thanks for your answer
Gordon atkinson tarafından
