Ana içeriğe geç
Grey Screen no reaction
Hi. I have MacBook Pro (15-inch Early 2011). On startup it shows folder with question mark. Internet recovery stuck on grey screen. Reinstalling from usb again stuck on grey screen. Doesn't open hardware test. Please give any idea
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
MacBook Pro 15", late 2011.
3hrs spent in Apple store in S.F. Tec ran hardware tests which couldn't complete diagnostics and tech suggested harddrive was the problem. His solution, use disk utility to install the OS over the old one, (didn't work), and then to erase the HD and do a system reinstall. Also didn't work! Went to another Apple store, Berkeley, and tech there repeated tests and then performed test of video card. When that also failed, she suggsted that problem was a bad video chip on the logic board. So --- whole logic board needs replacement.
Th Is would be the 2nd time video chip failed. The first time, 2015, Apple replaced the logic board under a special progam because of the widespread failure of the video chip. However, I was told that program ended 8 minths ago. Now I have to pay for the replacement!
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I actually had this logic board replaced at Apple's expense also, due to some California specific legislation which compels Apple to continue replace defective logic boards beyond the time limits of whatever previous warranty repair plan was.
tarafından
Yorum Ekle
Yanıtını ekle
Vardan Hovsepyan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 450
