Ana içeriğe geç
Üstten ve önden yüklemeli Whirlpool marka çamaşır makineleri için onarım kılavuzları ve destek.
How to fix error code F08 or FOB
Washing machine starts up and after 2 seconds it stops and this code came up. Have to reset the washer cause the door locks. Ive tried various different loads and even a empty load but no luck.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
2 Yorum
fscr10420 error f08
tarafından Paylaş
I have had a brand new machine installed Friday the 10th,the very first wash came up F08,have phoned manufacturers and Indesit,,they have booked a appointment for 5 days,this should haven't happened as brand new.
tarafından Paylaş
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
jmears83 , You did not state your model #. This is info i had come up with, F08 indicates that the heater is an open circuit. Check the heater wires for dislodged or burnt wires and check the heater for continuity with a meter.
Check the link below for further info. and view the video. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.espares.co.uk/advice/0/3521/w...
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
hi
me i have replace the heater and the ntc at the same time the cable system is ok but the problem still going...what else i have to do???
tarafından Paylaş
Yorum Ekle
I have the same problem. Replaced the heater, washer functions normally except for the error at the end of the washing when it shows F08. My brother also had the same issue but his machine was repaired at the shop. Mechanic couldn't figure it out (why it is still showing error) so he reprogrammed control unit just for that…
Puan 1
1 Yorum:
ok very usefull info but unfortunally here in company nobody knows how to reprogramming ,,,all says to replace the control unit and my friend this costs money ..(for nothing????).
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
jmears83 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 82
Her zaman: 68,547
