How can I fix the charging port.
How to fix the charging port.
Bu iyi bir soru mu?
@popspad ,Nancy, Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link(1st)choose your model and pick a disassembly guide to see how to open your Tablet to check the charge port and will also post a 2nd link showing what is involved in repairing a mini USB attached to the board. The last link is to new charge port, which you can also do a search for using your model# or may have to visually match. If needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 2,950
