Ana içeriğe geç
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Where to by pass with the jumper
My lid lock assembly only plugs into one spot and that's the control board do I go to the lid lock assembly under the hood and cut the wires and bypass it or do I pull the plug from the control board and jumped it there if I have to do it under the machine at the assembly I'm going to have to wire nut the wires together it's model# 1105072011 Kenmore residential washer or wire harness red white blue and yellow wires please help I have 5 kids and haven't done laundry in 3 days I tried to fix this all weekendthank you
Bu iyi bir soru mu?
Puan 6
3 Yorum
so I join red and blue together and white and yellow?
tarafından
@mrt22431 applying a jumper is not quite the same a joining them together. Get a piece of cable with some alligator clips or either end and connect as suggested in the answer
tarafından
Where does the grey wire from the lid switch harness plug in under the washer on a kenmore 80 series. The wire came unplugged when the motor was removed to replace a part
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
@grim69
bypassing the the lid switch should be Blue and White (2and3 on J15) the lid switch . To bypass the lock switch should be #3 on J15 to #5 on J16. Careful of the voltages.
Bu yanıt yardımcı oldu mu?
Puan 3
16 Yorum:
Then should I jump both locations to eliminate the entire assembly
tarafından
So white to blue on J15 and white to white on J16 please let me know if this is correct thank you
tarafından
That sound sabout right and looks correct on the schematic. Just mind the voltage. you got 120V on that
tarafından
I just cleared the drain pump had a sock stuck in it started the machine would not lock so put the dial in drain and it drained so should I only have to jump the lock switch or lid switch or the lock switch or still both getting closer thank you
tarafından
most likely just the lid switch since the solenoid for the lock switch is activated differently.
tarafından
11 tane daha yorum göster
Yorum Ekle
En Yararlı Yanıt
Here's what to do till the part comes in:
https://www.youtube.com/watch?v=j8rrZIxA...
Puan 5
2 Yorum:
What gauge ( size) wire should I use, or does it matter?
tarafından
I'd use a 16 or 18 gauge wire.
tarafından
Yorum Ekle
As the original answer stated with schematic. Blue to white on j15 will get you the lid sensor. White to white on j15 to j16. If you want lid sensor and lock sensor. Combine all 3. . J15 is cut blue +white. And I nicked the j16 white and spliced online.
Doing a load now. Worse case you just need to unplug machine to reset it, but at that point who cares.
Puan 0
Yorum Ekle
Yanıtını ekle
Eddie lynn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 149
Her zaman: 39,612
