Ana içeriğe geç
Japonya dışındaki tüm pazarlarda üçüncü nesil Toyota Camry. 1991-1996 modelleri, XV10 serisi Camry araçları olarak da adlandırılır.
Cam sensor location no spark issue
I have been trying to get this car going for about a year.told that the cam sensor is gone and need to replace it.now I'm no expert but I do know that I have watched a few videos on YouTube and where they show the cam sensor to be at it isn't..Then told that it's apart of the distributer shaft.!!!!! So if that's the cam where's the Crank shaft sensor? I ts a no spark issue
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@lowvisions , Patrick , On the 2.2l engine, crank position sensor is behind the crank shaft pulley/balancer. Picture below(crank sensor circled). For the V6 3.0l almost same position, see video link. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=M6zU6jh8...
Resim
Bu yanıt yardımcı oldu mu?
Puan 3
4 Yorum:
I'm sorry I should of mentioned that I have a 3.0
tarafından
Patrick, For the V6 3.0l almost same position, see video link. Thanks for replying back.
tarafından
On the 2.2 do u have to take the timing cover off to get to the sensor
tarafından
We have a 1996 Camry LE 2.2L 4 Cylinder... I have bought the crankshaft position sensor, I just dont know where the heck to install it, where is the old one? Anyone know? I searched it up on youtube but i could not find anything. I hope someone can help
tarafından
Yorum Ekle
Hi for all Ihave toyota corolla 1993there’s no cranck shaft sensor but there's acumshaft sensor biultin within the main distributor shaft making signale to the ECU of the car
Puan 0
2 Yorum:
Well I have remove my 2.0 l and installed a 2.2 l engine , and the car didn't use a distributor , it uses coil which depend on a crankshaft sensor
tarafından
@elicaannephembani And the point of bumping a thread that's almost 2yrs old is...? Are you having issues? Or what?
tarafından
Yorum Ekle
Yanıtını ekle
Patrick sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 89
Her zaman: 10,689
