Ana içeriğe geç
Shuts down every 30 mins
Hi ,
I have a dell laptop Inspiron 14 z
I tried using it with n without plugged in power supply , no use
Battery is 100 % charged .. Bt still no use
It shuts down exactly after 30 mins !!!
After it shuts down if I on it again it works perfectly fine again for 30 mins and gets shut down again....
I tried reformatting it ..
Changes the os
Bt nothing works
Got it check by an engineer he opend d laptop n check everything looked fine ... He applied thermal paste or something, Bt he said there no heating issues !!
If there's a heating issue it shouldt start again , bt here it start n works normally bt jst for 30 mins plz help me with thz...
Bu iyi bir soru mu?
Puan 2
2 Yorum
Try taking the battery out, and using it with no battery and let me know how that works out. Thanks
tarafından
I have issues like this:
i just install updated Intel 4000 Driver and now my laptop shut down every 30 min before update driver my laptop fine, hope my answer fine for everyone, i' not sure. maybe Driver Couse this problem
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
@devils , Dhaval, Not a heat issue, check for errors in event viewer and see if any error code. Check the settings in Power management - it is set to shutdown after 30 minutes. Go to Control Panel, Power Options, and change the setting. Still no go try reseating the memory modules and test the system. If the system still turns off, then try one module at a time on each slot. Still no go install a new cmos battery. Run a good virus/malware scan to see if infected. Check the links below for more trouble shooting of this problem as they had identical issue. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.tomsguide.com/answers/id-2207...
https://www.bleepingcomputer.com/forums/...
Bu yanıt yardımcı oldu mu?
Puan 5
Yorum Ekle
@Ipfaff1
In d event viewer
It says
Event 41, kernel -power
The system has rebooted without cleanly $@$*!&%& down first . This error could be caused if the system stopped responding , crashed , or lost power unexpectedly
Level -critical
I have no idea what it means !!!
Puan 0
1 Yorum:
My dell laptop automatically shutdown slove my problem
tarafından
Yorum Ekle
I also browsed internet for 2days.
Still didn't abled to solve it myself.
I have a 2011 version acer laptop.
And at the end,gave it for repair.
Problem was with Heating Paste.
Puan 0
Yorum Ekle
Yanıtını ekle
Dhaval sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 44
Her zaman: 18,006
