Ana içeriğe geç
The Ryobi P202 part of the Ryobi One+ series. This model is an 18-volt cordless 1/2 inch drill, and is bright green and grey in color. It has a built in level gauge and a two gear ratio switch on the top of the drill, along with a direction switch, magnetic tray, and drill bit clip.
release the chuck with stuck drill bit
I have a stuck drill bit in the chuck. How can I release it?
Bu iyi bir soru mu?
Puan 2
2 Yorum
Is this a student question?
tarafından
1. Put the drill in reverse.
2. Set torque to highest setting.
3. Put one of 3 things on the chuck:
a.) Vise Grips
b.) Channel Lock Pliers
c.) Rubber Jar Lid Opener
Turn on the drill and the bit WILL POP RIGHT OUT!
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
fionashanahan, If really stuck, give a touch of penetrate oil down the jaws of the chuck, put the drill in reverse, firmly grip the chuck with gloved hand and gently squeeze the trigger up the point that you cannot hold on. If it still doesn't budge and you're not able to hold the chuck against the force of the drill. Get 2 strap wrenches(they will not damage the chuck) one to hold the chuck and one to hold the collar, may need an assistant. With the strap wrenches both in position, adjust the slack out of them firmly hold the collar with the one wrench and turn the other in counter clockwise direction to break chuck free. Posted a couple video links below that may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=iPQTwLQs...
https://www.youtube.com/watch?v=R0hQ9nnX...
Bu yanıt yardımcı oldu mu?
Puan 5
3 Yorum:
Thanks but tried everything and no luck
Why on earth do we have these chucks when this problem appears so common- nothing wrong with the chuck key chuck!! Also should not have bought a Cheap Chinese Drill - previous (chuck key) drill was really good but was stolen and I just needed a cheap fix; now I’m paying for it in blood sweat and tears.....
tarafından
Thank you I forgot that all drill chucks can typically be manually loosened you saved me alot of headache bc the drill is my mother's so thank you again
tarafından
Get a large wrench or small hammer and give the chuck a couple of swift whaps and reverse chuck like normal...it will come right out
tarafından
Yorum Ekle
There’s a youtube video that unstuck my drill bit:
https://www.youtube.com/watch?v=A6pFgdcL...
Puan 2
2 Yorum:
I have a key type Chuck stuck open I've tried vise and channel lock, vise grips, broke all the teeth on my key and it's still stuck. It's been soaked with PB Blastern cleaned with carb spray, and soaked again with PBB. Tapped the side of Chuck with small copper faced hammer and tapped on each tooth with a mild steel probe and hammer. It's still stuck! I've noticed that almost all the questions I've seen have been hammerdrills.
tarafından
Remove chuck from drill if you can...either way lock it or the drill in a vise and heat it up real good with some kind of torch..MAPP gas ....Propane..even oxy acetylene but use a small brazing tip not cutting torch or rosebud...when it's good and hot..squirt it with penetrating oil should fix you right up..
tarafından
Yorum Ekle
The clutch is the problem, I can hold the chuck.
Puan 1
Yorum Ekle
Check warranty first, My Ryobe p252 was out of warranty, and other answers methods no joyp. I had to disassemble the drill and remove the gear housing down to the sheilded bearings around shaft. (leave ball, and roller bearings in chuck alone and in place) Once machined shaft end is exposed table clamp it, and use channel locks to turn chuck counter clockwise. If chuck ball, and roller bearings came loose, dismantle chuck from screw located inside chuck mouth to reseat.
Puan 0
Yorum Ekle
I lubed the chuck with WD40, then held the chuck and drilled in reverse a few times. This didn't do it until I tapped on each jaw with a chisel and hammer (in the axial direction). This unlocked the chuck.
Puan 0
Yorum Ekle
Yanıtını ekle
fionashanahan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 44
Son 30 gün: 206
Her zaman: 68,072
