Absolutely no sound from Ipad 2
After battery, digitizer, and widi antenna replacement sound no longer works from headphone jack or speakers
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Try cleaning the charging port, sometimes it gets oxidized and gives such fault. If you can replace it with a working one it would be even better.
Bu yanıt yardımcı oldu mu?
I will try a new chare port
Unfortunately that did not seem to fix the issue. I ordered new speakers and headphone jack assembly
I'm a bit skeptical that will fix the issue, but there isn't much else left apart from a problem on the board itself. Hope you will succeed.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 816
1 Yorum
Did verify conn before putting digitizer on
Bradley Crawford tarafından
