Ana içeriğe geç
Bilgisayarınızın onarım sorularına çözüm bulun.
21230 Soru Tümünü görüntüle
Ground loop - is that the problem and how to fix it
I have what I suspect to be ground loop. The 3.5mm cable between the line in on my PC and the line out on my monitor is producing a strange buzzing noise. I've tried removing the ground connection between the two, but it didn't help. What I'm really looking for is verification that the problem is really ground loop.
Recording of sound:
https://drive.google.com/file/d/0BxmOW-d...
Supposed solution:
https://www.amazon.com/gp/aw/d/B019393MV...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum:
Anybody got any ideas?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
hello George A. did u fix these buzzing noises ? was it ground loop ? did that mpow ground isolator solve that ? im asking because i have same problem right now
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
No, I didn't buy the ground loop isolator but if you have the problem you should try that. I didnt buy it because I found another solution: to not use a 3.5mm connection.
tarafından
Yorum Ekle
Yanıtını ekle
George A. sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 190
