Ana içeriğe geç
Mazda tarafından üretilen, Mazda Axela olarak da bilinen ikinci nesil Mazda 3 sedan ve hatchback serisi.
Revs too high after service
After taking the car for a second service to reduce the revs I still find them higher than when I bought it. The mechanic said all he did was reset the computer. Is there a way I can change the computer settings or how would I go about changing the revs?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
countparas, You can not change the cars computer settings with out special scanner/software/knowledge as normally found at a dealership or well equipped shop.
Ask the dealer ship/shop to show you the cars idle speed specifications cold/warm(operating temp.), if idle speed is in the parameters should probably not adjust further. If not in parameters they should correct the issue. Whether by adjustment/faulty sensor, vacuum leak,throttle body sticking/dirty or having to change program in computer. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Your mechanic needs to set the rev limiter on the computer.
Puan 1
Yorum Ekle
Yanıtını ekle
countparas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 1,644
