Ana içeriğe geç
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
Front Camera not detected and Rear Camera distorted
So my LG G5 has this problem, the wide angle rear camera doesn't work in the camera app because the camera app thinks it's the front camera, so I have to switch to the front camera in the camera app, and it'll show the wide angle camera. The problem with this is that it's all distorted. Not only is that, but the front camera may be broken, I want to confirm here, I checked the cameras in AIDA64, and it only shows the 2 rear cameras connected, it doesn't show the front cam at all, anywhere, as if there was no front cam plugged in. I was thinking if I should replace the front camera. Can anyone confirm or anyone else have this problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
Was the phone damaged? And how?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Unfortunately, in situations like this, there is no possible way to 100% confirm that this will fix the issue, unless someone has seen the issue personally before, and even in that situation, that person may have had a different issue causing the same symptom.
As a technician, my order of operations would be as follows for this issue,
1) Cashe Wipe/Factory reset
2) New front camera
3) New back cameras module
4) reflow on Camera Data Line
5) Motherboard
the most effective way to go through this procedure, would likely be to pay a technician to do this, however, if you insist on trying yourself, I would purchase from a retailer that allows returns. If you do this, you can buy all of the components, then return the ones you don't need. this will save you time in the entirety of the process.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Same problem in my mobile instead of opening front it openss. Rear wide cam…in cam it shows unfortunately stoped
Puan 0
Yorum Ekle
I'm very curious about how this turned out for you as I'm having the exact same problem with my G5! I've searched relentlessly and all I can find are posts regarding the focus issue with rear cam. Please update on how you fixed the issue if you don't mind! Thanks!
Puan 0
Yorum Ekle
Yanıtını ekle
jamesbadan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 1,162
