Sounds buttons up works but not down.
The volume button only works for the up button. but not the down.
I do not see any replacement part for this or any kind of repair mentioned anywhere.
Hope you can help.
Bu iyi bir soru mu?
Hope you can help.
Bu iyi bir soru mu?
Stephen, The 1st link is a disassembly guide which will get you inside the Tab to check the volume button from the inside to see if it is sticking/dirty, can be repaired or you may have to replace the Power/volume button flex shown in 2nd and 3rd link. Always verify part correct for your device before placing order. You can also do a search for better pricing perhaps using full model#. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement
http://www.ebay.ca/itm/OEM-SAMSUNG-GALAX...
[bağlı ürün eksik veya kapalı: IF249-030]
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 60
