Ana içeriğe geç
ZenFone 5, Asus tarafından üretilen ve Mayıs 2018'de piyasaya sürülen 6,2 inçlik bir akıllı telefondur. Telefonun arka kısmında iki kamera bulunur ve Meteor Grisi ile Gece Mavisi renk seçeneklerine sahiptir.
What is the RF cable for?
I replaced the screen on my Zenfone 5 and accidentally clamped down on the RF cable while reassembling. When I connect my phone to computer using USB cable, the android drive does not appear. I have MTP turned ON and USB debugging ENGABLED. Is this because of damage to the RF cable? Because previously my computer used to detect the android drive.
Please help.
Much appreciated,
Ray
Bu iyi bir soru mu?
Puan 0
1 Yorum
Nope,. RF Cable is only for the signal of your device. try to Hard Reset your Smartphone and also to change your USB Cable.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
The RF coax cable you damaged was either for your WiFi or Bluetooth antenna. That is if your Cellular service is still working.
Even though you are trying to use the USB connection your settings may still be setup using the WiFi or Bluetooth to make connection. Which is why it is failing to work.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
It probably is, if you need to transfer files, you need a new cable or you need to put them in some cloud storage and access them from your computer.
Puan 1
Yorum Ekle
Radio Frequência (RF) , provavelmente vc ficará sem conexão ou de dados, Wi-Fi ou Bluetooth...
Puan 0
Yorum Ekle
Yanıtını ekle
[deleted] sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 2,018
