Ana içeriğe geç
Amazon'un Kindle Paperwhite serisinin bu sürümü 30 Haziran 2015 tarihinde piyasaya sürülmüştür. Kindle Paperwhite 3. Nesil, Wi-Fi özellikli 6 inç, 300 PPI okuma ekranına sahip bir tablettir. Belirlenen model numarası DP75SDI'dır.
Frozen unresponsive screen. Can it be repaired?
Hi!
I have a Kindle Paperwhite, 6" High Resolution Display (300 ppi) with Built-in Light, Wi-Fi - bought in October 2015.
Kept well, it hasn't fallen down, nothing untoward. Stopped working. The screen had an erratic display for a while, and has now stopped responding.
Can anyone help?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
1 Yorum
I am having the same problem, could you find a solution for this? Please let me know.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had this problem with an e-reader and it turned out that it quit charging. After placing the e-reader on a new charger it started working again. The models we use in our school are all nooks but this may help you out too.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Hey! Thank you so much. But this one is charging. No problems with that. Just that the screen gave an erratic display and then stopped responding. I am trying to understand if it is a screen or motherboard issue. Will try and fix it accordingly.
tarafından
Yorum Ekle
Did you find a solution to this? I am having a similar problem
Puan 0
2 Yorum:
... me too!!!
tarafından
@skeeve205 could you please let me know if you found a solution for this?
tarafından
Yorum Ekle
Try tapping (or knocking with your nail) in the bottom right corner of the front. (Edit: you can also try bringing a magnet to that corner and bringing it away)
If it responds, then I have a workaround for this, that I’ll publish as a “technique” guide within the next few days. (EDIT: here it is!) The only problem with that guide is that it will no longer respond when opening/closing the cover
Puan 0
Yorum Ekle
Yanıtını ekle
Anamika Das sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 5,225
