Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
Shield connector broken-phone won't turn on
Looking for help please.
I have an iPhone 6 that won't switch on.
It connects to a pc via the cable but nothing on screen.
All that I can see wrong inside the phone is that the small flex connector at the bottom of the shield, that takes the home button flex - is totally ruined.
2 previously functioning screens are not firing up on this device.
Would this broken shield connector stop the screen working all together? Or just effect the home button functionality?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
7 Yorum
Here's what I know so far:
-The phone appears dead after a screen replacement
- The shield flex that takes the home button flex is damaged.
- When connected to a pc, the phone appears on screen as a device (although with no screen to respond on, I cannot authorise access)
-When connected to a charging source, I get no signs of life via vibration when switching the mute button on and off.
- I DO get a small vibration response when I press the power button and the two volume buttons (diagnostic snapshot?).
Could the phone be stuck in some kind of state, and need a power/home button reset (which I can do when I restore the home button connection)?
tarafından
Just replaced the metal shield plate and reinstated the home button connection.
Still having the same problem.
tarafından
Does iTunes or 3UTools report anything about the phone being in recovery mode? Or for 3UTools normal mode as well?
tarafından
No sign of this unfortunately
tarafından
Can you upload a picture for the damage before buying anything?
tarafından
2 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Normally that would just effect home button functionality but other times it can effect other things my advice is try a battery replacement usually the culprit 90 percent of the time
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I've got a new shield arriving today, and if that doesn't work, will try a new battery next
tarafından
Yorum Ekle
Try to boot up your phone whitout connecting the home button flex.
Puan 1
5 Yorum:
To be honest, the shield flex connector is so broken, it is as good as disconnected already. There are gold teeth missing from the connector.
Home button connector is in good shape thankfully.
tarafından
I would still disconnect the home button extension cable because just having it plugged in stopped my iPhone from booting Edit: (I even unplugged the home button from the extension cable too).
I just had a customer come in today to replace broken extension cable home button stopping boot. Usually they are faulty when the metal plate is missing for home button connector.
tarafından
I've heard of this stuff happening. From a very unreliable tech. Not saying you guys. But when I would try to recreate these errors, I can't seem to get it to do it
tarafından
I know the home button extension cable has to be broken in a certain way which is weird.
I've had other damaged home button extension cables that would just not allow the home button to function, so they break in different ways.
Picture of the metal piece that separates from extension cable if not pryed properly:
http://prntscr.com/ewp9uf
tarafından
Just tried with the home button disconnected but no joy unfortunately. Ill add another post with what ive done/found so far.
tarafından
Yorum Ekle
Yanıtını ekle
Lee Barnes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 93
