Ana içeriğe geç
Released in 2013, the Alienware X51 R2 is an updated version of the original Alienware X51 desktop gaming computer. It has a compact case, but can be upgraded with many off-the-shelf PC components.
2 Soru Tümünü görüntüle
Getting stuck in a reset loop. reset, boot, reset, boot, reset,boot
I am getting random BSOD showing up on my X51 R2. It all started after a windows 10 update (I already had 10). The computer sometimes games for an hour and other times only 2 minutes before showing a BSOD and getting stuck in a boot/ reset cycle. It resets, boots for 1-2 seconds with the fan on full speed, then resets. This cycle carries on indefinately until I turn off the mains power.
I found a windows STOP CODE on a BSOD... 'BAD_POOL_HEADER'
I have seen 6 different windows stop codes
Looking into the 'fault memory' of the computer it is not logging these crashes as faults as there is no sign of a crash or reason
Please help#!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I've looked up the model X51 R2, there are various configurations, if you could tell me more about yours I could help more, what mobo, how much ram etc
However in the mean time you could try the following if you could confidently open and remove the ram sticks.
  1. Turn off and remove power cable.
  2. Open case and identify where your ram is.
  3. On the motherboard beside the ram slots there should be (although not always) numbers that indicate what order the rams slots are in, if not, remember what order they are in (or take pictures). Usually the slot furtherest away from the cpu is the first slot. Or refer to your mobos manual if you still have it.
  4. Remove the all the ram.
  5. Take one stick a put it in the first slot, sometimes called slot 1, sometimes 0.
  6. Try to boot.
  7. If you still get the error you may have found the dud stick.
  8. Power off the pc remove power cable.
  9. Remove the stick.
  10. Put in the other stick.
  11. Power on.
One of many things can happen now;
It works, in which case you have the bad stick in your hand
It doesn't work, both sticks somehow died at the same time (extremely unlikely), OR your ram slot is damaged.
Let me know how you get on.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Dan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 1,815
