Any recommendations for overhauling a 2007 MacBook Pro?
I have a MacBook Pro from 2007.
I've replaced the hard drive after a crash. Considering upgrading RAM.
While I'm in there for the RAM, anything else I should modernize?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Not much you can upgrade in this series other than the Drive & RAM.
This system is limited to 4 GB of RAM and the drives SATA port is limited to SATA I (1.5 Gb/s) so you do need to be careful on what drives you go with as faster drives may not work in this system.
You'll need to review the drives specs sheet to see if SATA I speed is supported. If it's not listed it's not supported!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 147
1 Yorum
Your systems specs: MacBook Pro 15" 2.33 GHz Core 2 Duo
Dan tarafından
