Ana içeriğe geç
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
Is there a 'unibody' Mac mini teardown manual?
We're looking into getting a new unibody Mac mini soon. We wanted to know if the new thicker hard drives would fit. Does anyone know if there is a unibody teardown manual that might have this information?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
From a visual standpoint it looks like these use 9.5mm drives from the factory. These may take 12.7mm drives, but I'd check with a deck of cards to be sure unless you have a spare 12.5mm drive you can quicky use. If you'd rather be safe stick to 7-9.5mm drives. However, you need a drive with a SATA II compatibility mode and cannot use a Fixed III drive.
Follow this guide to change the hard drive.
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
Thank You nicksmacandpchelp!
The current Mac mini is MC270*. Is there much difference between it and the A1347?
tarafından
+ The MC270 is the A1347.
tarafından
OK, THANKS for clearing that up.
tarafından
Yorum Ekle
Yanıtını ekle
AngelArs sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,453
