Ana içeriğe geç
Kasım 2016'da piyasaya sürülen, Nintendo Entertainment System'ın modern ve mini bir sürümü. Bazı pazarlarda Nintendo Classic Mini NES olarak da bilinir.
Micro-USB power port is broken
The micro-USB power port on my NES classic broke. Is it an easy fix, and where can i get a replacement port?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@wackowax ,Waqas, If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide/vid. to get you inside the Nintendo Classic Mini NES to check the charge port and will also post a link(not your device) showing what is involved in repairing a mini USB attached to the board. You can do a search for replacement port or you may have to try visually matching it up(may be standard type). If not wanting to attempt the repair have a couple good local game/computer repair shops have a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.theverge.com/2016/11/13/13614...
https://www.youtube.com/watch?v=Ov-HACi9...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Waqas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 31
Her zaman: 3,804
