Alright. Error 4013 sounds like a nand issue. Likely cold solder joint. Let's try Mohammadali's approach. You could remove the pentelope screws, carefully remove the home button clasp and cable, then remove the two screws on the battery plate, then disconnect the battery, reconnect and carefully re apply everything. Also, while doing this. Be careful of the display cables at the top. Make sure they are always close, so as not to damage them. Then try putting the phone into dfu mode. Here's a guide for the phone, and I'll post steps to put phone into dfu mode
How to replace the battery in your iPhone 5s
Remember, you don't need to take the whole battery out. Just remove cable. Replace cable
Plug your device into your computer with a USB cable.
Turn off the device.
Hold the Power button for 3 seconds.
Hold the Home and Power buttons for 10 seconds.
Release the Power button but keep holding the Home button.
Here's some steps to try to get your phone into dfu mode. Also can you tell us what happened? Why are you trying to restore it? Was there damage? Water?
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
4
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
6 Yorum
i try a coupe more restore, now i dont see the red screen flash, when it finish extracting the software, the phone goes black and then the apple logo, then i see like a timer spinning in circle for about 1 second, then it went black then to the apple logo, then its back to the recovery mode again.
Charles tarafından
@arynov @imedic Thanks for all your help. I sold it for scraps, didnt want to mess with it anymore, as its out of my league with the display.
cli168 tarafından
If for some reason it didn't work you can always download an external program to help restore your phone to working order without losing any of your data. One such program is called iOS System Recovery.
It can do more than just release you from the white screen of nothingness, and save you from recovery mode, black screen or if you are stuck in a start menu loop. It can correct ios system issues and help with iTunes errors.
https://www.forecovery.com/fix-ios/iphon...
NinaOrtiz tarafından
Im About Try Out What @ninaortiz said
IOS User tarafından
Actually, This method can get iPhone out of recovery mode easily.
iPhone Stuck in Recovery Mode
danPeele tarafından
1 tane daha yorum göster
