Ana içeriğe geç
Model: Dell Vostro 1440/1450/1540/1550 Çıkış Tarihi: 2009
My motherboad is short curcuit
When i plug the power adapter into my laptop mother boad ... adapter light was get off ... and i unplug the wire within motherboad and ac current.. and then i plug again only to ac current then light geting lightup may can i get my mother boad schematic diagram...please...
Bu iyi bir soru mu?
Puan 1
2 Yorum
@nsandanuwan check your power supply first. It sounds like it works for as long as there is no load on it. Once you apply a load to it, it seems to fail. As for a schematic, there are a few different logic boards for this Dell. You do want to open up your laptop and tell us what label the board has.
tarafından
processor cooling fan voltage not getting what problem may be
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@nsandanuwan if your power supply checks out okay you want to start with to measurements on the board. See attached image. Possibility is a failed component (we still need to get the proper board number from you) like a failed resistor.
Resim
Here is the complete DC schematic for the DV15HR board. You can use the test points as shown in the schematic to see where you have power etc.
Resim
Bu yanıt yardımcı oldu mu?
Puan 1
6 Yorum:
cooling fan voltage not gert
tarafından
@BHAGWATI PRASAD Joshi is this a question or an answer?
tarafından
cooling fan voltage not getting what is the cause rest circuit is ok
tarafından
@BHAGWATI PRASAD Joshi on your computer?
tarafından
cooling fan voltage not getting what is the reason
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Nirosha sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 820
