Ana içeriğe geç
2.3L 4 silindirli veya 3.0L V6, 6. Nesil
I need a redio codes
Hello I need a redio codes of my car engine D14Z6
Bu iyi bir soru mu?
Puan 17
27 Yorum
I need a redio code honda accord 1998
tarafından Paylaş
David, you can get a radio code here: https://radiocodevault.com/honda
tarafından Paylaş
is there a sequence that you have to put the numbers in
tarafından Paylaş
The http://radiocodevault.com website worked for me as well :)
tarafından Paylaş
22 tane daha yorum göster
Yorum Ekle
9 Cevap
Filtre ölçütü:
Seçilen Çözüm
I had this same issue after disconnecting my battery, what ended up working was using that site https://radiocodevault.com/honda/ and then having them send me the unlock code that matched with my radio. Music again, finally…. :) Hope it helps some people out still searching for a solution to this.
Bu yanıt yardımcı oldu mu?
Puan 15
6 Yorum:
Yup this one worked with my civic, can vouch
tarafından Paylaş
thank you worked for my car stereo
tarafından Paylaş
Those guys are the true pros for radio unlocking. Gracias for unlocking my Honda!
tarafından Paylaş
thank you for this!
tarafından Paylaş
Actaully the site doesn't even exist any more thanks @%^$$@$#
tarafından Paylaş
1 tane daha yorum göster
Yorum Ekle
Okay I spent about 4 hours researching this topic. Here is what ended up working for me. It worked on my Honda Accord, but it should work on all models of Honda and Acura actually.
You can use the following link for reference, as they have detailed instructions as well:
Get detailed instructions here (they also provide radio codes): https://radiocodevault.com/honda
So your radio is probably displaying something that says code or something like this.
If it is saying error/ERR/ or anything like that, I’d highly recommend checking out the reference site I posted above.
Code = Needs a radio code
Err = error from locking up, and you’ll need a radio code
Err1, Err2, Err3 = stop messing with your radio! This is very important…
Okay now that you know all of that.
Please check the comments below, as I’ll post all the steps there.
Puan 7
5 Yorum:
Step one: Turn the radio off.
tarafından Paylaş
Step two: Hold the 1&6 button on your radio at the same time (if there is no 1&6 button, just go to the reference site I listed in the main post)
tarafından Paylaş
Step three: While the 1&6 are being pressed, turn on your radio at the same time.
tarafından Paylaş
Step four: This might show your radio’s serial number, if it does write it down for the final step. If it does not do anything, go here: https://radiocodevault.com/honda and fill out their form with the serial number blank, and they can help.
tarafından Paylaş
Step five: If you have it, enter your serial number on https://radiocodevault.com/honda and you'll get an email with your unlock code pretty quickly. That's it! Good luck.
tarafından Paylaş
Yorum Ekle
Step 1: Turn the Honda ON, and the radio should turn on automaitcally but if it doesn’t turn it on.
Step 2: Then turn the radio OFF
Step 3: Hold the 1 & 6 preset buttons on radio
Step 4: While still holding 1 & 6, turn the radio back on
Write down the 8 numbers that display on the screen
This is your radio’s serial number.
Go to https://radiocodevault.com/honda/ and enter your serial number
They will also probably require your VIN# which you can find very easily on your car by checking alongside the door when you open it.
From what I’ve heard they send out codes 2-3 times per day directly to your email
Just enter the working unlock code into the radio using the same preset buttons (the numbered buttons) and you should be all set and having your radio working again!
It seems complicated, but its not. Just follow the steps and you’ll be fine.
P.S if your Honda is before the year 2000, just go to that unlocking service site and enter your VIN# and leave the serial number blank. The older models usually have extra steps you have to do in order to obtain the serial number. Usually you have to remove the radio first, and the serial number you’ll need is on the back label that says HONDA.
Cheers!
Hopefully this saves some people hours of research and hassle :P
Puan 6
2 Yorum:
Don't use the website mentioned above!!! They will charge you for the code! Use owners.honda.com for the code. It is FREE and easy.
tarafından Paylaş
The https://radiocodevault.com/honda website worked for me actually, no problems, thank you so much. Thanks berrya.
tarafından Paylaş
Yorum Ekle
I got a working Honda radio code from https://radiocodevault.com/honda/
Puan 2
4 Yorum:
I followed all the steps and everything was coming up roses until it came time to have the reset code sent to me and then in order to get the code they wanted 14.95. By no means am I spending 14.95 on a radio reset code for a 2002 accord. I guess I will go as is or does anyone have a free suggestion. 14.95 you gotta be kidding
tarafından Paylaş
Use owners.honda.com it is free and easy.
tarafından Paylaş
Jim and dodie (the commenters above) just sound like cheapskates lol. Thanks for this solution, they gave me a working code. These "free" options just waste your time. Paid a professional, and had it handled quickly. Thanks Anne for posting this.
tarafından Paylaş
the radiocodevault crew actually came through on it. got my code easy. thank u for the link
tarafından Paylaş
Yorum Ekle
Try 65664
worked for my 2002 accord
Puan 2
1 Yorum:
Every unlock code is unique, so this won't work.
tarafından Paylaş
Yorum Ekle
@itoperez there are a couple of things you can try:
1. Look in glove box for small sticker with numbers, should be 5 digits with numbers no greater then 6.
2. Pull out the ashtray and see if the sticker is on the back of there.(older models that have them)
3. Pull radio from dash and write down radio serial number and call local dealer with that number and they will be able to get the code for you. They will ask verifying questions.
One more thing you can do is that Honda has a radio reset website, this is an automated service that can provide your Honda stereo code. Just write down the serial number of your radio and the VIN number of your vehicle then contact Honda. The VIN number is located on the driver side of your Accord vehicle just behind the windshield.
Resim
You could also give this a try:
Turn car to ON II(radio powers up)
Turn radio off
Hold 1 & 6 buttons on radio
While still holding 1 & 6, turn radio on
Write down the 8 digit number that should display
Call your Honda dealer and give them those numbers. Or you might want to try this one online. https://radio-navicode.honda.com/
Puan 1
1 Yorum:
This is the Honda website to get your code to activate your Honda radio. I just bought my 2002 Honda Accord private sale and it did not have a radio. Went to the junkyard and bought one. It needed a code to activate it. This site is free, and easy. Just follow the instructions.
tarafından Paylaş
Yorum Ekle
Super easy. Turn your radio off, press the numbers 1 and 6 simultaneously, then turn on the radio. It should show you a U And L number. Write the numbers down, and go to this link. https://radio-navicode.honda.com . Then put in the U and L numbers together in the serial number without the letters U and L. And put in your Vin number, phone and email. It will give you a code, so enter that into your radio! I didn't want to call Honda too so here you go.
Puan 0
Yorum Ekle
Go too owners.honda.com it is free and easy. Don’t use the website mentioned in the above comments. They will charge you to get the code.
Puan 0
Yorum Ekle
Followed the above but, when you pull the fuse don’t reinstall right away, I turned on the car the reinstalled and error code was gone then put in the radio code!
worked great, thanks all
Puan 0
Yorum Ekle
Yanıtını ekle
ZAINA HAMID sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 23
Son 30 gün: 138
Her zaman: 107,777
