you can try the following:
Cover the hole with some painter's tape, and break a hole through the pinhole again, make sure the painter's tape is covering the pin hole's surrounding properly.
Next, use wood glue to try and attach another wooden coffee stir to the broken piece in the pinhole. You can use wood glue generously as it can always and easily be peeled off before completely drying hard.
The tricky part will be to create some kind of support for the wood coffee stir stick to hold in place until the glue dries.
You can always substitute for super glue as a quick solution, but if it fails, you can imagine i can have a higher risk of making a mess and even minor damage. Either way super glue is not super risky.
Finally, a last idea is to see if it would stick to play-doh or mounting poster putty tack. Simply roll a small ball of it, lightly press it against the hole, and slowly pull. Poster tack is much better for this as its' consistency is harder, and much superior stickiness to playdoh.
Hope this helps!
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
