Ana içeriğe geç
The Kingston HyperX Cloud II Gaming Headset is a headset designed by Kingston. This device comes with a headset, removable microphone, and an inline USB audio controller and is compatible with most computing devices. Model number: KHX-HSCP-RD
Headset cable broken cannot rewire
So after using the HyperX Cloud 2 for like 7 months I cannot hear anything from the right ear cup.
This happened when I was playing CS:GO.
I played several times with the cable going up in the headband, that's why the cable broke. (Check image)
(It's actually the other cable going up in the headband that broke)
I tried to wire them back and plug it in. It didn't work because the green wire has a special coating ? (Check Image)
(Not the broken wire)
(The broken wire)
Now only the mic and the left ear cup is working, what can I do to fix the wire problem ?
I tried to wire them back together but it didn't work because of the special coating i'm guessing ?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You need to strip the coating. I suggest using a lighter to melt it off. I found that works the best. After its stripped, you need to resolder the cables together, which i assume you know how to do.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thank you so much, i'll try that today.
tarafından
Can you not use the lighter to remove the special coating and wrap them together? The same as using speaker wire or does it have to be soldered?
tarafından
Yorum Ekle
Yanıtını ekle
musa_a sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 7,481
