Ana içeriğe geç
Phone not turning on, no leds blinking at all!
My mi 5 was rooted and was installed with aosp rom. I downloaded a battery calibration app, where it was instructed to start calibration and then when the phone switches off it should be charged to a 100 percent. I had unplugged my phone at 97 percent, but I couldn't switch it back on. There were no leds or anything. I also tried to charge it but now it wouldn't show anything . How can I fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 10
10 Yorum
me too i have the same problème.
tarafından
Hi,
I had a similar problem, my phone turned of and I wasn't able to turn it on, or charging, there wasn't any leds.
I repaired it by opening my phone (very easy) and unpluged an repluged the battery connector.
I think there is a generic default with xiaomi mi5 battery...
Hope it helps !
tarafından
Wow great answer Geoffrey had the same exact problems and followed your advice found a tutorial on how to disassemble a xiomi 5 on you tube opened it unplugged replugger the battery and now it works !!!!!
Thanks again Geoffrey I how you a beer !
tarafından
I have the same problem. Any solution?
tarafından
Dizefurkan,
You can open your phone and unplug then replug the battery connector (you will easily find a tutorial for it), I made this a few times, but I think, it's just a temporarly solution, mine juste completely die after 8th times...
tarafından
5 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hope it helps !
by Geoffrey Borelli
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hi
Try yo flash marshmallow roms via fastboot or mi flash
Puan 0
1 Yorum:
will it work?
tarafından
Yorum Ekle
Yanıtını ekle
Fragout Gaming sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 67
Her zaman: 7,073
