Ana içeriğe geç
250 GB HDD ve dahili Wi-Fi ile klasik Xbox 360'ın ince versiyonu. Onarım, karmaşık bir şekilde ayırma işlemi ve özel tamir aletleri gerektirir.
Red dot blinks 11-12 times
My Xbox 360 slim will not boot up after turning it on on the green button turns red and blinks about 11-12 times with a loud fan noise then shuts back off. I have looked everywhere for a fix for this and have found nothing except people with the same problem. This video is exactly what mine does and there have been no fixes for it yet. https://www.youtube.com/watch?v=yMwajymV...
I have no warranty and already taken it apart to clean it but it really did nothing. Does anyone know how to fix this? I would be super greatful for a solution.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I got the same problem. The overheating is the issue. I replaced a few bad resistors from the link below and it worked for me.
https://www.youtube.com/watch?v=bNEsEkrn...
GL,
Kevin Tran
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
Mine makes the sound but without the fan or the lights coming on. I tap the power button and nothing happens
tarafından Paylaş
This definitely works for the blinking red dot failure. However, whoever tries to do this fix, know that you are getting into a really REALLY precise soldering work. You'll need a fine tip for your soldering iron, a really good set of eyes or a big magnifying glass/bench mircoscope, and a very steady hand.
Thank you for pointing into the right direction, Kevin!
tarafından Paylaş
oh my that’s just lovely
tarafından Paylaş
Yorum Ekle
I have an Xbox 360 s with the Kinect. 1439 is the model. I had this same exact issue except our light blinked about 30 times while the fans ran fast. I checked all of our resistors and 1 of them resistor 407 had about 100 ohms. I added a drop of solder to jump it and checked it with a meter again and it said 0 ohms. So I plugged it in and she is all backup and running.
The video posted above helped out a lot.
Hope this helps you out.
Puan 1
Yorum Ekle
Yanıtını ekle
Shian Lawson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 23
Son 30 gün: 90
Her zaman: 19,660
