Ana içeriğe geç
Fast charging not working properly
Hi!
A week ago, I received my galaxy s8+ as a pre-order. The phone worked properly, until it didn't charge fast anymore... everytime I plug in my charging cable (the same cable and adapter that came with the phone) a pop-up appears saying that it can only charge slow and I had to be sure that the charger was plugged in properly. I then tried cleaning the port with a thin plastic stick. This worked for about an hour, whereafter it stopped working. Until now, it still takes 6 hours for a full charge..
Does anyone know how I can clean the port properly, without damaging it?
Thanks in advance!!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
I'd take it back for warranty. Sounds faulty to me.
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
@benjamen50
Thanks for your reply!
I Will bring it back.. however, I did root my phone. Is it possible that i can unroot the phone and then bring it back for warranty?
tarafından
I don't know about that though because it will say knox warranty void 0x1 in the download mode on screen which technically means warranty voided so you can only try.
tarafından
Sometimes if you buy refurbished device, these problems are normal.
Fast charging can get damaged when the device is opened and repaired.
https://www.bestphonerepair.com.au/galax...
tarafından
It could even be the root (as it uses different kernel) stopping fast charging from working if it happened right after rooting it.
tarafından
Yorum Ekle
I had the same symptoms and warning messages. Fix was simple - dust/fluff had got into the charging port. A quick squirt with a can of compressed air, and everything was back to normal.
Puan 1
Yorum Ekle
Have you tried checking settings to see if fast charge is enabled?
Sounds stupid but i found that to happen once or twice on mine.
also you could purchase a USB voltage detector online which are a few quid,
and see the voltage going in to the phone?
Hope this helps.
Puan 0
Yorum Ekle
Yanıtını ekle
nabil sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 31
Her zaman: 9,250
