Ana içeriğe geç
Apple TV, Apple tarafından tasarlanan ve 21 Mart 2007'de piyasaya sürülen bir dijital medya alıcısıdır.
Why have they all started jumping?
I have 3 Apple TV 1st generations and they have all developed exactly the same fault at the same time. Coincidence? They no longer play saved content (films) without constant pausing and. Jumping. Has anyone else experienced this issue and - if so - what's the fix? I have tried a factory restore on one, but no ch age.
Bu iyi bir soru mu?
Puan 1
2 Yorum
Are you connecting to the same TV? Are these devices hacked (like Kodi or jailbroken)?
tarafından
Hi, they are attached to different TVs (the same ones that they have each been attached to for ages) and have not been hacked.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check your local connection (Ethernet or WiFi) internet connection if you are streaming as that maybe the real issue.
If you live in a dense area its likely someone is stepping on your WiFi band if you are using WiFi to connect the Apple TV to your Internet Router. If you are using wired Ethernet connection then it could be an ISP issue.
If you have a Mac give this app a try: WiFi Explorer it will allow you to see the bands that you and the others around you are using.
Bu yanıt yardımcı oldu mu?
Puan 2
14 Yorum:
Thanks,but would that affect the playing of movies saved onto the Apple TV 1st generations own hard drive?
tarafından
No, But to be sure I would disconnect the network connection (Ethernet or WiFi) as their maybe some other process running in background which is having an issue.
tarafından
I also need help for this
Same as what @ispl said
"playing videos on the apple tv hard drive"
Please help
tarafından
@beanman56 - The drive maybe failing or highly fragmented so the movie is to badly scattered across the platters.
tarafından
Ok thanks for the help,
Also @danj do know what format it takes for external drives?
tarafından
9 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
pipbaldwin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 644
